cooling fan
my toshiba c70-a-130 laptop in the last two weeks the fan on a couple of occasions has suddenly fired up for a few seconds,then then went quiet again,but at the same time a message appears pops up saying theres a problem with the cooling system turn of the computer and return it for a service, on the toshiba health monitor it shows the fan speed at 49%. I have since used air duster to dislodge any dust.
my laptop is widows 8.1..... A Sattallite c70-a.....
cpu..intel® pentium ® cpu 2020m @ 2.40ghz
physical memory. 4096mb ram.
is what i have descibed caused by dust or something more serious. thank you.
michael flynn
Operating system:Windows 8.1 (64 bit)
System root: C:Windows
Available physical memory: 3987 MB
CPU: Intel® Pentium® CPU 2020M @ 2.40GHz
C: 454.90 GB
Internet Explorer: 11.0
Link to comment
I had Toshiba, when i used it in bed or my lap it started to overheat, at 95*C it AUTO SHUTS OFF to prevent any damage.
what i did;
+ regular cleaning of all posible air holes, vents (vacuum cleaner + air compressor - if you can, BLOCK the fan to prevent spining when using air compressor)
+ i upgraded BIOS
+ bought hard plastic pad / still using it
NEVER EVER HAD that problem again!   :D
I hope it will help u also.
http://forums.toshiba.com/t5/General-Troubleshooting/Cooling-Warning/td-p/150883
http://botcrawl.com/warning-a-problem-with-the-cooling-system-has-been-detected/
Link to comment
