Alf Posted July 3, 2014 Report Posted July 3, 2014 Har en tilårskommen HP laptop med Microsoft vista32. Programmet Wisw Care 365 vil ikke starte på denne maskinen. Får melding: Wise Care 365 har sluttet åvirke et problem førte til at programmet sluttet å fungere som det skal. Programmet vi bli lukket, og du vil få beskjed hvis den løsning er tilgjenelig. Operating system:Windows Vista Home Premium (32 bit) Service Pack 2 System root: C:\Windows Available physical memory: 3069 MB CPU: AMD Athlon X2 Dual-Core QL-62 Drive Info: C: 222,77 GB D: 10,11 GB Internet Explorer: 9.0
xilolee Posted July 3, 2014 Report Posted July 3, 2014 translated from norwegian Program will not run Has an aged HP laptop with a VISTA32. The program Wise Care 365 will not start on this machine. Getting message: Wise Care 365 has stopped working a problem caused the program stopped working properly. The program we will be closed and you will be notified if the solution is AVAILABLE. Possible error message (English): Wise care 365 has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. Where do you have downloaded wise care 365? From wisecleaner downloads? What version do you have downloaded (version number)? Is your program registered (pro) or free? I.e., do you have a license key? Have you already tried to uninstall/reinstall it? Have you tried the portable version? Have you tried to start your machine in safe mode (click) and seen if the program works? And with a clean startup (click)? What final message do you get after launching sfc /scannow from an elevated command prompt (windows installation cd could be necessary, the command lasts 20-50 minutes)?
Alf Posted July 3, 2014 Author Report Posted July 3, 2014 Hi I hawe don al of this. Nothing helps. The owner of this pc want i back, so I uninstall the program and he must have to live with it. Thanks Alf
