abusafar Posted June 2, 2014 Report Share Posted June 2, 2014 very slow to start the pc i instaled wise care 365 also!! Operating system:Windows 8.1 Pro (64 bit) System root: C:\WINDOWS Available physical memory: 4087 MB CPU: Intel® Core2 CPU 6300 @ 1.86GHz Drive Info: C: 55.00 GB D: 50.00 GB E: 43.94 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted June 2, 2014 Report Share Posted June 2, 2014 Check How to speed up your PC or try these operations: 1) If the warranty has expired, you could try to open your PC (first unplug it from the mains...!) with a lot of caution and, gently, remove the dust with a brush and vacuum cleaner (or hair dryer) and apply the thermal paste to the processor. 2) Open an elevated command prompt and type: cleanmgr /sageset:65535 Press enter, tick every option inside cleanmgr advanced menu, click ok, then type this: cleanmgr /sagerun:65535Press enter and wait until it finishes. 3) Download adwcleaner portable (click) and run it. 4) Download wise care 365 portable (click), extract it and put it on your desired/preferred folder. 5) Create a system restore point (or let it create by WiseCare, it should ask it to you the first time you run it) 6) Double left-click wisecare365.exe, click custom checkup, select/tick all entries (or the entries that you prefer), click ok, click checkup now, wait until the scan finishes, click fix now. 7) Click the third tab at top: system tuneup On the left, click the fourth tab: startup manager Remove unnecessary items (keep enabled antivirus and processor items) 8) Launch sfc /scannow from an elevated command prompt (and report the result here) 9) Defrag your hard disks (it may take hours... Try first the OS partition only). If you often get BSODs, skip this. Keep us informed. Link to comment Share on other sites More sharing options...
