Chet Posted May 16, 2014 Report Share Posted May 16, 2014 Running XP moving files has become very very slow. Moving either from folder to folder on the same drive, or from one drive to another. And Windows sometimes crashed durring the move. Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 1535 MB CPU: Intel® Pentium® 4 CPU 3.20GHz Drive Info: C: 465.76 GB D: 186.31 GB Internet Explorer: 8.0 janettefb3 1 Link to comment Share on other sites More sharing options...
Jayzx Posted May 17, 2014 Report Share Posted May 17, 2014 Hi, try this: 1. run system cleaner, specially registry. 2. scan for viruses, malwares and spywares, if there are remove them. 3. disk maybe fragmented, run disk defrag and optimize. 4. uninstall unused programs/ useless programs (apps may vary) 5. startup programs maybe overloaded, disable programs @ startup not needed to run immediately @ task manager. 6. stop running too much apps and programs at the same time, endtask programs running in background not needed @ task manager. 7. memory maybe running full, delete unnecessary/unused files. (use also disk cleanup) 8. there maybe corrupt files, run cmd and type "sfc /scannow" (without quote) after 100%/completed/successful reboot pc. 9. update your drivers. 10. ram maybe running full (will alert you if it is) 11. upgrade to win8 or 8.1 12. computer maybe dusty, clean pc (do with caution) Link to comment Share on other sites More sharing options...
