GeorgPC Posted February 15, 2014 Report Share Posted February 15, 2014 Nach Windows neu Instalation werden alle Geräte und Drucker im Fenster angezeigt, aber nach paar Tagen sind sie wieder weg. Weis nicht warum? wie kann man es beheben? Betr.System: Win7 prof.64 Bit Komp.: 8GB RAM, 1TB Platte, i7-2600K CPU Operating system:Windows 7 Professional (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 8159 MB CPU: Intel® Core i7-2600K CPU @ 3.40GHz Drive Info: C: 390,40 GB E: 540,89 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
UCanFixIt Posted February 15, 2014 Report Share Posted February 15, 2014 Translated: After restart Windows instalation all devices and printers are displayed in the window, but after few days they are gone. Do not know why? how can you fix it? Hi GeorgPC, Just a hunch but is there any chance you are using Bluetooth devices? If so, please unplug those devices and see if you can access that view after doing so. OR, try unplugging all peripherals for that matter and see if that works too! Please consider my suggestions as uneducated guesses at this point but they may be worth a try. Also, if using Bluetooth, make sure all necessary Bluetooth services are started: Note: I do not use Bluetooth. You may have multiple services that are associated and required to be running. Again, just a hunch so good luck! UCanFixit Link to comment Share on other sites More sharing options...
xilolee Posted February 16, 2014 Report Share Posted February 16, 2014 Check also if Bluetooth support service status has been set to manual and that doesn't exist another Bluetooth service. Another try, from an elevated command prompt: net stop spooler del /Q /F /S "%systemroot%\System32\Spool\Printers\*.*" net start spooler Link to comment Share on other sites More sharing options...
