Icon frozen
Desk top icon have frozen, I cannot open or zip the files as the icons are frozen pls advise the solution to fix it please.
Many thanks
System root: C:\windows
Available physical memory: 8136 MB
CPU: Intel® Core i7-2670QM CPU @ 2.20GHz
C: 654.69 GB
D: 29.00 GB
Internet Explorer: 11.0
Link to comment
It would help to know if you did anything right before the problem started. Things like installing new programs, downloading and applying new Windows Updates, and/or any hardware changes might be the cause of your issue. However, there is no way to make that determination based on your brief description. Anyway, you can start off by disabling all unnecessary startup programs to see if that eliminates your issue. If so, start re-enabling them one-at-a-time until the problem returns. I am also assuming you have not contracted any malware; however, it might not be a bad idea to run a full malware scan with your AV software. See Method Three here and good luck.
Startup Programs - Change
Link to comment
 Share
