не работает защита системы
Translated: protection system is not working
Unfortunately, all of the necessary information appears to be contained in the view you posted; however, we do not have any participating members that can read/translate Russian to English (to the best of my knowledge). So, if you want to continue your support effort in this forum, you will have to take the time to explain what that view is actually showing us and tell us exactly what it says.
Good luck.
Link to comment
Hi kristn777! :)
1) Run sfc /scannow from an elevated command prompt, wait until it finishes, check the result (and send it to us), reboot your pc.
2) Copy the following text into notepad, save the file as W7SP1UltimateDefaultServices.bat (it should not be saved as txt and its icon should not be a paper), run it as an administrator, check if there are any error messages and paste them here... If there are no errors, reboot your pc.
@echo off
sc config AeLookupSvc start= demand
sc config Alerter start= disabled
sc config ALG start= demand
sc config AllUserInstallAgent start= demand
sc config AppIDSvc start= demand
sc config Appinfo start= demand
sc config AppMgmt start= demand
sc config AudioEndpointBuilder start= auto
sc config AudioSrv start= auto
sc config AxInstSV start= demand
sc config BDESVC start= demand
sc config BFE start= auto
sc config BITS start= demand
sc config Browser start= demand
sc config bthserv start= demand
sc config CertPropSvc start= demand
sc config ClipSrv start= disabled
sc config clr_optimization_v2.0.50727 start= demand
sc config COMSysApp start= demand
sc config CryptSvc start= auto
sc config CscService start= auto
sc config DcomLaunch start= auto
sc config defragsvc start= demand
sc config DeviceAssociationService start= demand
sc config DeviceInstall start= demand
sc config DFSR start= demand
sc config Dhcp start= auto
sc config dmadmin start= demand
sc config dmserver start= auto
sc config Dnscache start= auto
sc config Dot3svc start= demand
sc config DPS start= auto
sc config DsmSVC start= demand
sc config DsRoleSvc start= demand
sc config EapHost start= demand
sc config EFS start= demand
sc config ehRecvr start= demand
sc config ehSched start= demand
sc config EMDMgmt start= auto
sc config ERSvc start= auto
sc config EventLog start= auto
sc config EventSystem start= auto
sc config FastUserSwitchingCompatibility start= demand
sc config Fax start= demand
sc config FCRegSvc start= demand
sc config fdPHost start= demand
sc config FDResPub start= auto
sc config fhsvc start= demand
sc config FontCache start= auto
sc config FontCache3.0.0.0 start= demand
sc config gpsvc start= auto
sc config helpsvc start= auto
sc config hidserv start= demand
sc config hkmsvc start= demand
sc config HomeGroupListener start= demand
sc config HomeGroupProvider start= demand
sc config HTTPFilter start= demand
sc config idsvc start= demand
sc config IKEEXT start= demand
sc config ImapiService start= demand
sc config IPBusEnum start= demand
sc config iphlpsvc start= auto
sc config KeyIso start= demand
sc config KtmRm start= demand
sc config LanmanServer start= auto
sc config LanmanWorkstation start= auto
sc config lltdsvc start= demand
sc config lmhosts start= auto
sc config LSM start= auto
sc config Mcx2Svc start= disabled
sc config Messenger start= disabled
sc config MMCSS start= auto
sc config mnmsrvc start= demand
sc config MpsSvc start= auto
sc config MSDTC start= demand
sc config MSiSCSI start= demand
sc config msiserver start= demand
sc config napagent start= demand
sc config NetDDE start= disabled
sc config NetDDEdsdm start= disabled
sc config Netlogon start= demand
sc config Netman start= demand
sc config netprofm start= demand
sc config NetTcpPortSharing start= disabled
sc config Nla start= demand
sc config NlaSvc start= auto
sc config nsi start= auto
sc config NtLmSsp start= demand
sc config NtmsSvc start= demand
sc config p2pimsvc start= demand
sc config p2psvc start= demand
sc config PcaSvc start= demand
sc config PeerDistSvc start= demand
sc config PerfHost start= demand
sc config pla start= demand
sc config PlugPlay start= auto
sc config PNRPAutoReg start= demand
sc config PNRPsvc start= demand
sc config PolicyAgent start= demand
sc config Power start= auto
sc config ProfSvc start= auto
sc config ProtectedStorage start= demand
sc config QWAVE start= demand
sc config RasAuto start= demand
sc config RasMan start= demand
sc config RDSessMgr start= demand
sc config RemoteAccess start= disabled
sc config RemoteRegistry start= demand
sc config RpcEptMapper start= auto
sc config RpcLocator start= demand
sc config RpcSs start= auto
sc config RSoPProv start= demand
sc config RSVP start= demand
sc config sacsvr start= demand
sc config SamSs start= auto
sc config SCardSvr start= demand
sc config Schedule start= auto
sc config SCPolicySvc start= demand
sc config SDRSVC start= demand
sc config seclogon start= demand
sc config SENS start= auto
sc config SensrSvc start= demand
sc config SessionEnv start= demand
sc config Sharedaccess start= disabled
sc config ShellHWDetection start= auto
sc config SNMPTRAP start= demand
sc config Spooler start= auto
sc config sppsvc start= auto
sc config sppuinotify start= demand
sc config srservice start= auto
sc config SSDPSRV start= demand
sc config SstpSvc start= demand
sc config stisvc start= demand
sc config swprv start= demand
sc config SysMain start= auto
sc config TabletInputService start= demand
sc config TapiSrv start= demand
sc config TBS start= demand
sc config TermService start= demand
sc config Themes start= auto
sc config THREADORDER start= demand
sc config TrkWks start= auto
sc config TrustedInstaller start= demand
sc config UI0Detect start= demand
sc config UmRdpService start= demand
sc config upnphost start= demand
sc config UxSms start= auto
sc config VaultSvc start= demand
sc config vds start= demand
sc config VSS start= demand
sc config W32Time start= demand
sc config wbengine start= demand
sc config WbioSrvc start= demand
sc config wcncsvc start= demand
sc config WdiServiceHost start= demand
sc config WdiSystemHost start= demand
sc config WebClient start= demand
sc config Wecsvc start= demand
sc config wercplsupport start= demand
sc config WerSvc start= demand
sc config WinDefend start= auto
sc config WinHttpAutoProxySvc start= demand
sc config Winmgmt start= auto
sc config WinRM start= demand
sc config Wlansvc start= demand
sc config wmiApSrv start= demand
sc config WMPNetworkSvc start= demand
sc config WPCSvc start= demand
sc config WPDBusEnum start= demand
sc config wscsvc start= auto
sc config Wsearch start= auto
sc config wuauserv start= auto
sc config wudfsvc start= demand
sc config WwanSvc start= demand
pause
3) Check if system protection now works
Looking forward for your kind feedback.
Link to comment
 Share
