Printer won't communicate with computer
My os is Windows 7 Home Premium. I have a Lexmark X5650 all-in-one printer. Although the printer still functions, i.e., copies, auto feeds paper, etc., and print jobs are shown clearly in the print queue, there is a connectivity problem which is preventing the jobs in the queue to print. I have tried uninstalling the printer, updating both Lexmark and Windows drivers, checking my firewall settings, checking that this printer is set as the default, and nothing has worked. I bought a cheap HP printer, installed it, and it prints perfectly. But no matter what I do, I can't print on the Lexmark. In desperation, I'm thinking about reinstalling Windows 7, but I'll also have to reinstall everything else that's on the computer. Can you help??
System root: C:\Windows
Available physical memory: 3839 MB
CPU: AMD Athlon II X4 645 Processor
C: 913.84 GB
E: 0.10 GB
Internet Explorer: 10.0
Link to comment
Hi jhs1941! :)
Have you already downloaded and installed these files from lexmark?
1) Complete drivers and software for setting up, configuring, and using your device with Windows 64-bit (click) --- Windows 7 (64-bit) --- USA --- English
2) 64 bit Core driver for the Lexmark 5600 Series-minimal print and scan drivers with supporting software (click) --- Windows 7 (64-bit) --- USA --- English
Is the print spooler service (start --> services.msc (press enter)) started , with startup = automatic ?
Link to comment
  • 2 weeks later...
When first booted up, one print job will print from the queue. If I send a second job to the queue, the only way to get it to print is to reboot the computer. I bought another inexpensive printer and it works properly, but it doesn't have the features that my primary printer has, i.e., no fax capability, no automatic feed function. I have tried downloading the most current drivers, both Lexmark and Windows, but that hasn't helped. I've tried an alternate USB port on my computer, there's no difference. Any suggestions?
C: 913.84 GB
E: 0.10 GB
Internet Explorer: 11.0
Link to comment
Print spooler directs and stores print information from the CPU to the printer. If it is not working or giving some error, then:-
please try the steps below,
  • Click Start=>Settings=>Control Panel=>Administrative Tools=>Component Services
  • Click Services (Local)
  • Scroll down to print Spooler
  • Right Click--properties--- make it Automatic
Link to comment
  • 9 months later...
