siwela Posted October 30, 2013 Report Share Posted October 30, 2013 the computer is very slow to perfom any task.i do not know,maybe i must change the operating system,xp is veryslow Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 1527 MB CPU: Genuine Intel® CPU T2400 @ 1.83GHz Drive Info: C: 74.52 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
april Posted October 30, 2013 Report Share Posted October 30, 2013 Did you try the last solution in Wise PC 1stAid? Link to comment Share on other sites More sharing options...
Adam Posted October 31, 2013 Report Share Posted October 31, 2013 The first you can unload your present PC system . Because when you use PC system over one year it often make PC operate slowly. The second If you don't want to change your system you can use Wise Care 365 to do thoroughly cleaning . The third you can update your Physical Memory up to 2048MB. I think the the first two ways can be as your priority. Hopefully your PC will work faster though these solutions. Link to comment Share on other sites More sharing options...
