KeesF Posted October 19, 2013 Report Share Posted October 19, 2013 Het maken van een restorepoint (herstelpunt) geeft de volgende foutmelding: 0x80042306 Operating system:Windows 8 Pro with Media Center (64 bit) System root: C:\Windows Available physical memory: 12106 MB CPU: Intel® Core i7-3630QM CPU @ 2.40GHz Drive Info: C: 118,28 GB D: 679,10 GB Internet Explorer: 10.0 Link to comment Share on other sites More sharing options...
april Posted October 22, 2013 Report Share Posted October 22, 2013 Follow the following steps below:1. Open The RUN Windows And Type "regedit" And Press Enter2. Than Open The "HKEY_LOCAL_MACHINE\SYSTEM\Setup"3. Than Find The Following Files In The Right Panel Of WindowSystemSetupInProgressUpgradeInProgress4. And Right Click On The Files And Change The Value "0"5. Than Close The Apps And Restart The System Than Access The System Without Any Error.Good luck! Link to comment Share on other sites More sharing options...
