bobkreeger Posted October 15, 2013 Report Share Posted October 15, 2013 Can't install any pdf printer drivers. I get the mesage to contact my system admi., in windows xp I am the admin. Help, have tried ro install several ways, nothing works. Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:\WINDOWS Available physical memory: 2814 MB CPU: Intel® Pentium® 4 CPU 2.80GHz Drive Info: C: 74.50 GB D: 232.88 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
april Posted October 16, 2013 Report Share Posted October 16, 2013 Click Start > Control Panel > Devices and Printers Select Add a printer Select Add a local printer Check Use an existing port and select Documents\*.pdf (Adobe PDF) from the drop down. Click Next Click the Have Disk… button Click the Browse… button Navigate to C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\Xtras\AdobePDF Select AdobePDF.inf from the list, then click the OK button You will see many Adobe PDF Converters in the list, however count six down from the top and click Next (you may need to try this numerous times to find the correct Converter from the list that works with your version of Windows) Name your printer, e.g. Adobe PDF Follow the rest of the prompts and your PDF printer should now be installed correctly Thanks. Link to comment Share on other sites More sharing options...
bobkreeger Posted October 16, 2013 Author Report Share Posted October 16, 2013 tried, doesn't work. Link to comment Share on other sites More sharing options...
WiseCleaner Posted October 17, 2013 Report Share Posted October 17, 2013 Please tell us your printer type. And do a snapshot of the error message, send to us. Link to comment Share on other sites More sharing options...
bobkreeger Posted October 17, 2013 Author Report Share Posted October 17, 2013 I fixed the problem myself, thank you for the help! Link to comment Share on other sites More sharing options...
