sanjay210 Posted July 1 Report Posted July 1 If your OneDrive storage is filling up with duplicate documents, photos, videos, or other files, it's important to clean them up carefully. Deleting files one by one can be time-consuming, and it's easy to remove the wrong copy by mistake. Using a duplicate finder makes the process much safer because it checks the files before removing them. The SysInfo OneDrive Duplicate Remover scans all selected folders in your OneDrive account and detects duplicate files automatically. Once the scan is complete, you can preview the duplicate items, review the storage summary, and choose which files should be removed. If you're unsure, you can move the duplicates to the OneDrive Bin instead of deleting them permanently. This gives you the flexibility to recover files later if necessary while keeping your important data safe and your cloud storage organized.
