Posted
A database administrator once tried to repair a damaged MDF file using DBCC CHECKDB, but the command kept failing due to severe corruption. With no backup available, it seemed like the data was lost. Instead of relying only on SQL Server tools, they tried SysInfo MDF Recovery Pro. The software didn’t require DBCC CHECKDB—it directly scanned the MDF file and started rebuilding the database structure. After the scan, it displayed recoverable tables and records, which they restored into a new database. This showed that you can fix corrupt SQL MDF files even without using DBCC CHECKDB when you choose the right approach.
