sanjay210 Posted April 10 Report Posted April 10 To fix issues while trying to import PST to Yahoo Mail, first check the basics. If you’re using Outlook manually, make sure IMAP is enabled in Yahoo Mail and the account is configured correctly in Outlook. If emails are not syncing, re-add the account and ensure a stable internet connection. For missing emails or attachments, try importing data in smaller batches and avoid interrupting the process. Duplicate emails can occur if the sync restarts, so be careful not to repeat transfers. If the PST file is corrupted, repair it using Outlook’s ScanPST tool before importing again. To avoid most of these problems, an easier solution is using the SysInfo PST Converter Tool. It directly imports PST data to Yahoo Mail without Outlook, keeping emails, attachments, and folder structure intact while reducing errors.
