sanjay210 Posted March 25 Report Posted March 25 Managing large contact lists in vCard format can become overwhelming, especially when duplicates start to pile up. Manual methods are not only slow but also prone to errors. A more efficient way is to use a tool like SysInfo vCard Duplicate Remover, which is designed for bulk processing. It scans all contacts quickly, compares important details such as names, email addresses, and phone numbers, and removes duplicate entries in a single process. This approach saves hours of effort and ensures your contact list stays clean and organized.
nivalgarza Posted July 1 Report Posted July 1 If you need to remove vCard duplicates quickly from a large contact list, avoid checking every contact one by one. Manual cleanup becomes slow, and similar names can easily cause wrong deletions. The safer way is to make a copy of the original VCF file and check duplicates through fields like name, email address and mobile number. This helps avoid removing useful contact details by mistake. You can first try a copy of the VCF file with Softaken vCard Duplicate Remover so that you can preview the cleaned contacts before using the final output. Once the duplicate contacts are cleaned, open the cleaned vCard file and check a few important entries before importing it to your phone, Outlook, iCloud or any contact manager.
