Anuj22 Posted March 24 Report Posted March 24 Hi everyone, I’m looking for a simple and reliable way to open and convert OST files without using Microsoft Outlook or an Exchange Server connection. I have a few OST files that contain important data like emails, contacts, calendars, and tasks, but I’m unable to access them on my system. Is there any free or professional tool that allows: Viewing OST file data without Outlook Opening multiple OST files at once No file size limitations Option to convert OST files into formats like PST, PDF, or others
Charles Lowell Posted March 25 Report Posted March 25 Easily view and convert OST files by using dedicated third-party tools like WholeClear OST Converter, which allow you to open, scan, and export orphaned OST files to PST, HTML, or MSG formats. These tools provide a direct preview of emails and attachments without needing an active Exchange Server. The software is easy to work on all Windows and is compatible with all Outlook versions. The software offers a free demo version.
michaell Posted April 14 Report Posted April 14 To easily view and convert an OST file without Outlook installation, you need to utilise a professional tool like GainTools OST Converter. With the use of this utility, you can view or convert your OST data into multiple file formats. It provides you with a complete preview of your uploaded OST file. Also, the software is simple and easy to use; no tech skills are needed to utilise it. Moreover, the OST File Converter run flawlessly and smoothly in all editions of Windows OS.
