Posted
Sometimes, while converting Excel contacts to vCard format, organization or company details may disappear. This usually happens because Excel and vCard store contact information differently. If the conversion tool does not correctly match the organization column with the proper vCard field, that information may not transfer during the process. In many cases, this issue occurs because some converters have limited field-mapping support, which leads to incomplete contact data after conversion.
To solve this problem, you can use OSTtoPSTAPP Excel to VCF Converter. It is a reliable Windows-based offline application designed to convert Excel contacts into properly structured VCF files while keeping all contact information accurate and organized.
Key Features:
  • Smart Field Mapping: Properly matches Excel columns with the correct vCard fields, including organization details.
  • Preview Before Conversion: Allows you to review contacts before starting the final conversion.
  • Batch Conversion Support: Convert multiple Excel files at the same time.
  • Selective File Export: Export only the contacts or files you need.
  • Duplicate Data Control: Helps maintain clean and organized contact lists.
  • Supports XLS & XLSX Format: Works with both Excel formats.
  • Compatible with all Windows Versions: It runs with all Windows versions from 11 to 7.
  • Run with all Platforms: The VCF files work with all Platforms.
A free demo version is available for testing its features.
