Posted
Hello,
I hope someone can help me, I've lost all of my files in Wise Folder Hider. I'm panicking quite honestly. It started when one of the folders wouldn't open, so I closed down Wise Folder Hider and re-started but it still would not open. I tried all of the other folders, and they opened fine. So I tried to "unhide" and they have all disappeared? Please help me... Thank you
Posted
Dear user,
Sorry about that. Wise Folder Hider will not change or revise your folders or files' locations or contents if they are not displayed in the program, please try this:
1. Click the link below to download and run this tool to stop the protection of the Wise Folder Hider.
https://downloads.wisecleaner.com/tools/DelDriver.zip
2. After running this tool you need to restart the PC, please save your important files before restarting.
3. Then uninstall the Wise Folder Hider and you can find your files at the original locations
Please try some search tools to search your folder name to see if you can find it. You can try Wise JetSearch:
https://downloads.wisecleaner.com/soft/WJSSetup_4.1.4.219.exe
