dimpal Posted March 11 Report Share Posted March 11 If you use Outlook regularly for both personal and business purposes. And a password is used to protect your information. But, due to several problems, you are unable to open your PST file. So, even if your PST file got deleted due to some unknown reason, you should not panic. So you are using the SysTools PST Repair Tool now. This utility has the ability to search multiple PST files, repair multiple PST files and repair multiple Outlook. backup files at once. Allows export of perfect PST files in the following formats: PST, PDF, MSG, EML, HTML, and Office 365. Link to comment Share on other sites More sharing options...
petergroft Posted Tuesday at 05:50 AM Report Share Posted Tuesday at 05:50 AM Launch the ScanPST tool on your system and click the Browse button to select the password-protected PST file. After adding the PST file, click the Start button. Check the checkbox, 'Make backup of scanned file before repairing. ' And if the tool shows 'errors were found in this file,' then click the Repair button. This May Work, Peter Link to comment Share on other sites More sharing options...
