kapil singh Posted January 16 Report Share Posted January 16 MailsDaddy AOL email Backup software is a great solution for extracting emails, contacts, attachments, documents, calendars, and more from your AOL mailbox. This tool backup AOL Emails into your hard drive. The software works perfectly without facing any problems. The tool also preserves the hierarchy of AOL email data when transferring it in PST, MBOX, MSG, EML, HTML, and more formats. With the help of this utility, users can export one or more mailboxes in multiple formats(one at a time). The software also can handle the problem of downtime. It works smoothly during the entire AOL backup process. This tool is a well-developed application with robust features to provide error-free conversions. The most exciting part of this tool is that the user can back up one or more folders simultaneously. This tool also gives you a date filter option, with the help of which you can filter your emails by date. If you want to generate the log file of your backup process, this tool also provides you with the Create Log option. The application is expertise in backing up the entire data of AOL mailbox into Outlook PST and other file formats without any hassle. For More Information- <a href="https://www.mailsdaddy.com/aol-backup-tool/">AOL Backup Tool</a> Link to comment Share on other sites More sharing options...
petergroft Posted January 18 Report Share Posted January 18 You can backup AOL emails to external hard drive by following the steps below: Sign in to your AOL mail account. Open the email you want to save. Press Ctrl+S to save the source of the file. Choose a location to save the file and click on the Save button. Go to the saved file and change its extension from txt to EML. Greetings, Peter Link to comment Share on other sites More sharing options...
