ameliazoe Posted January 15 Report Share Posted January 15 Are you looking for a way to convert OLM files to PST files? You will find the complete method for exporting OLM to PST in this article. On both Windows and Mac OS, Microsoft Outlook supports two distinct file formats. Data files are created in the PST format for Windows and OLM format for Mac. Outlook users who switch from Mac to Windows or vice versa face difficulties as a result. The Mac OLM Converter is an option for Mac users. Manually Convert OLM to PST Step 1: Create an IMAP Account Step 2: Create a Mac Outlook IMAP account. Step 3: Export MAC Outlook mail to an IMAP account Step 4: Adding the IMAP account to Windows Outlook As can be seen, these manual steps are too time-consuming and difficult for non-technical users to complete. Adding the IMAP account to Windows Outlook As a result, I suggest using an automated tool to convert OLM files to PST files, which is both professional and the best option. These files can be easily converted in a single operation. Professional Way to Convert OLM to PST Sometimes, switching from Outlook for Mac to Windows Outlook to perfectly manage their emails and other personal information is difficult for users. To easily export all of your mailbox items from the OLM file to the PST format, you can use the SysVita OLM Converter Link to comment Share on other sites More sharing options...
nakir48 Posted January 17 Report Share Posted January 17 Try the most trustable software OLM to PST Converter to make instant conversion of OLM files from Mac Outlook to Outlook PST formats. This application provides authority to check live previews & scan all errors of OLM file items to make accurate migrations without any change. No technical skill is required to operate the app. It is a user-friendly application that you can choose to export in the way you would like. It is a straightforward app to install on your Windows. The GainTools OLM to PST Converter program has been designed to make migration from Mac Outlook to MS Outlook flexible & effortless. The feature helps to get the desired conversion results each time. It retains the original properties of OLM files. The advanced application supports entire data conversion. This tool is specialized in converting not only OLM to PST but also OLM to MSG, OLM to EML, OLM to MBOX & OLM to EMLX. Link to comment Share on other sites More sharing options...
petergroft Posted January 18 Report Share Posted January 18 There are four ways in the manual to convert OLM files to PST. Create an IMAP account with a Gmail account. Set up an IMAP account in Outlook Mac. Sync Outlook for Mac and IMAP accounts using a Gmail label. Exporting emails from Mac Outlook to IMAP. Regards, Peter Link to comment Share on other sites More sharing options...
