soniyasmith Posted September 21, 2022 Report Share Posted September 21, 2022 I wish to suggest trying vMail EDB to PST Converter Tool if you wish to pick the best tool for EDB to PST transformation. With the aid of this tool, people can convert all of the smoothly mailboxes of Exchange EDB files to PST platforms along with attachments like e-mails, connections, notes, calendars, etc. Users can transform their particular EDB data into PST, MSG, EML, HTML, vCard, Office 365, etc. The program aids all the MS Outlook versions like 2019, 2016, 2013, 2010, 2007, 2003, etc. take to its demo this is certainly no-cost variation export the first 30 items per folder. Some great new features of vMail Software · Export EDB to PST in different platforms like TXT, EML and HTML etc. · Recovers mails, associates, calendars, jobs, notes, inbox etc. · Filter based mailbox this is certainly brick-level for selective information recovery · Migrates EDB to Live Exchange and Office 365 · Export Public folder from EDB to PST, Live Exchange and Office 365 Know more info- vsoftware EDB to PST Converter Link to comment Share on other sites More sharing options...
annysmith Posted October 20, 2022 Report Share Posted October 20, 2022 If you are finding an appropriate explanation to convert Exchange EDB to PST then don’t worry. There are usually two methods to solve this difficult Manual and automated approaches. The manual way involves many routine and has many limitations. Some of them are- Time-consuming, Lengthy, Data loss is at higher hazard. Beginner users will not be proficient to use a manual practice suitably. To get a quick conversion without any data loss and in no time. One such application is GainTools Transfer EDB to PST Converter Tool. Link to comment Share on other sites More sharing options...
cenkboncuk Posted November 25, 2022 Report Share Posted November 25, 2022 SysOZ EDB to PST Converter application comes with an attractive and simple GUI which makes it more easily to use for everyone. To convert EDB data to PST follow the simple steps and import the entire data along with email, inbox, outbox, contacts, deleted items, drafts, calendars, sent items, notes and many more. This application has a facility which gives permit to transfer that data which you want to convert. You can convert your data into formats like MSG, HTML, PST and EML. Visit Official website: sysoz.com Link to comment Share on other sites More sharing options...
Pallavi Kumari Posted December 12, 2022 Report Share Posted December 12, 2022 If you are searching for the best method to convert EDB files to PST format. Then, you can use the software Aryson EDB to PST Converter. It is an effective and user-friendly tool that quickly and reliably converts Exchange EDB files into PST format. It provides an easy-to-use interface to easily convert EDB files into Outlook PST format. It can also be used to export emails, contacts, calendars, tasks, notes, and other items from EDB files. It supports multiple versions of Exchange Server, Outlook, Windows OS. The software is also capable of recovering corrupted EDB files and converting them into PST format. It provides advanced options to filter and search data based on a date range. It also offers a free demo version to check its features. Link to comment Share on other sites More sharing options...
petergroft Posted January 6 Report Share Posted January 6 Follow the below steps to convert EDB to PST file easily: Run Stellar Converter for EDB. Select the EDB file using the 'Browse' option. Click the 'Next' button to start the conversion process. Click 'Save' to save the EDB files into Different file formats. Select the 'PST' option to export Exchange mailboxes into PST format. Greetings, Peter Link to comment Share on other sites More sharing options...
