soniyasmith Posted June 20, 2022 Report Share Posted June 20, 2022 Download the free trial version for OST to PST Converter for Mac Software. This software is easy to work with and migrate the Offline OST file to Outlook PST file format. It also recovers OST file data along with whole corrupted Outlook OST email items such as - Inbox, outboxes, sent mail, note, task, journals, drafts, etc. By using this application, you can also save OST data in Outlook PST File format. It also works on all MS Outlook versions like 2007, 2010, 2013, 2016, and 2019. · Support All Outlook Versions OST File without any size limitation · Export the OST file along with all attributes without any data loss · lifetime license validity with 24X7 free technical support Know more info-vsoftware ost to pst converter Link to comment Share on other sites More sharing options...
Jimmywick Posted July 13, 2022 Report Share Posted July 13, 2022 Convert OST to PST Manually Open Outlook and go to the File menu. Select the Import/Export option. Choose Export to a file. Select Outlook Data File (.pst) Choose whether to export a specific folder or the whole account. Check the Include subfolders box. Next, select a destination for the Export, and then click Finish. Regards, J Wick Link to comment Share on other sites More sharing options...
jennycarnerj1 Posted September 20, 2022 Report Share Posted September 20, 2022 The SYSessential OST to PST Converter is the best option to convert an OST file to an Outlook PST with attachments. For quick, secure, and reliable results, most users tend to switch to expert methods. Work is made easier for all types of technical and non-technical users by its slick and simple GUI. Download its demo to test the tool and converts the first a few data items per folder. Link to comment Share on other sites More sharing options...
cenkboncuk Posted November 25, 2022 Report Share Posted November 25, 2022 SysOZ OST to PST Converter can convert your data into various formats like PST, MSG, MBOX, vCal, vCard, EML, EMLX etc. It shows the preview of a recovered mailbox along with all the data such as email, notes, task, attachment, contact, draft, inbox, and calendar (To, Cc, From, Date, Time, Subject, Object and Bcc). Try the free demo version of this tool to convert 30 emails for free. You can avail the 24X7 technical supports. SysOZ OST to PST Converter can recover and convert the password protected OST data. You can also do the OST data recovery without any data loss. Free Download SysOZ OST to PST Converter Software Link to comment Share on other sites More sharing options...
ameliazoe Posted January 15 Report Share Posted January 15 SysVita OST to PST Converter Tool is an easy way to convert an OST file database to the PST format. It lets you quickly export OST files into PST, EML, MSG, MBOX, RTF, Office 365, and other formats using a simple work user interface. The software makes it easy to restore all OST files that have been damaged or are impossible to access. Download free Software: visit: sysvita.com Link to comment Share on other sites More sharing options...
Johnjons Posted January 31 Report Share Posted January 31 You can easily migrate the Outlook OST file to Outlook PST file format. ToolsCrunch Mac OST to PST Converter Software recovers and corrupts OST file and also recover and delete OST file. It is a simple wizard that is easy to use for any non-technical user who wants to save OST files into Outlook data file format. Mac OST to PST Converter tool easily and fatly exports all email items like emails, Inbox, Outbox, notes, Messages, etc. This software supports all versions of MS Outlook & Mac OS. Support all Windows OS versions like - 11, 10, 8.1, 8, 7, XP, and Vista. Link to comment Share on other sites More sharing options...
romanlewis Posted February 25 Report Share Posted February 25 ToolsBaer OST to PST Conversion Tool effectively Converts Outlook OST files to PST format without any data loss. It also recovers OST file data along with whole corrupted Outlook OST email items such as - Inbox, outbox, sent mail, note, task, journals, drafts, etc. This software is safe and Bulk Conversion. Microsoft Outlook and Windows OS versions are supported by this program. It also supports all Mac OS versions. Install the free demo version of the software. Link to comment Share on other sites More sharing options...
ParulGupta Posted March 4 Report Share Posted March 4 If you are looking for a Windows solution to convert OST to PST file format, take the help of MailsDaddy OST to PST Converter Tool. Using this software users can export single or multiple OST files into PST format without any changes in the original content. It allows users to read the complete OST file databases in the preview section, like email, contact, calendar, notes, attachments, etc. Here users can convert OST to PST, EML, MSG, MBOX, RTF, HTML, EMLX, Office 365, Live Exchange Server, and others. To know more please visit the official site of MaislDaddy. Thank you! Link to comment Share on other sites More sharing options...
dimpal Posted yesterday at 11:33 AM Report Share Posted yesterday at 11:33 AM You can use this Convert for OST to PST by MSOutlookTools to convert files for MAC. An effective tool for converting data objects from OST to PST while preserving their related Metadata and other attributes, including emails, calendars, contacts, tasks, notes, journals, etc. No data will be altered when the OST to PST conversion is being done thanks to the utility. Link to comment Share on other sites More sharing options...
