alinayewagat 0 Posted February 9 Report Share Posted February 9 NSF to PST format can be migrated by using the Softaken Software and then you can open the NSF file. After the migration of the files, it becomes quite easier to open the file in the PST version. Not only in PST but also provide multiple file format like EML to PST, MBOX to PST, MSG to PST and DBX to PST its many more. Just you have to install the Software on your computer. Then you will have to utilize the Free Lotus Notes to Outlook Migration on the computer. Now scan the files and add the required NSF. After that option to check the preview Lotus Notes database will be displayed on the system. Choose the export to PST option and Select the desired database to export. More info: - Converter NSF to PST Link to post Share on other sites
