R.V.DAS Posted August 27, 2013 Report Share Posted August 27, 2013 Following error message appears when we try to open Device Manager, Services Etc "MMC will not run with a version of Internet Explorer earlier than Internet explorer 5.5." Though we are using I.E.version 9 ! Operating system:Windows Vista Home Basic (32 bit) Service Pack 2 System root: C:\Windows Available physical memory: 1013 MB CPU: Intel® Pentium® Dual CPU T2370 @ 1.73GHz Drive Info: C: 146.00 GB Internet Explorer: 9.0 Link to comment Share on other sites More sharing options...
april Posted August 28, 2013 Report Share Posted August 28, 2013 IE 9 for some reason does not include the version key in teh registery. To be precise, either it is not there or it gets removed when uninstalling some software with e.g.Wise Program uninstaller. To fix the problem simply one can type regedit in start->run and then go to: 1. HKEY_LOCAL_MACHINE->SOFTWARE->Microsoft->Internet Explorer, 2. go to menu Edit->New->String Value and name it Version , 3. click right mouse button on the new string key and select Modify, 4. type in the numbers from svcUpdateVersion key e.g. 9.0.6 (in my case). 5. close regedit, 6. restart Windows, and everything should be fine again. good luck! Thank you. Link to comment Share on other sites More sharing options...
