miker Posted August 21, 2013 Report Share Posted August 21, 2013 wirelessprinter not working Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:\windows Available physical memory: 3964 MB CPU: Pentium® Dual-Core CPU T4400 @ 2.20GHz Drive Info: C: 287.55 GB Internet Explorer: 10.0 Link to comment Share on other sites More sharing options...
Config Posted August 21, 2013 Report Share Posted August 21, 2013 Hi! Please cite your printer's brand, model and your operations before the problem occurred. Thx. Link to comment Share on other sites More sharing options...
WiseCleaner Posted August 21, 2013 Report Share Posted August 21, 2013 Hi, The printer do not working means not printing or can not connect? 1, can not printing, please contact to the printer providers to seek tech support . 2, can not connect: 1) check the connection from printer to wireless router, if it is good, note down the printer's IP address (e.g 192.168.1.123); 2) check the connection from PC to wireless router, if it is good, follow step 3); 3) click Start, type CMD in search bar, right-click it, select Run As Administartor 4) type ping 192.168.1.123 , press Enter If the result like image 1, back to step 1) and step 2); If the result like image 2, continue to step 5) 5) click Start----Device and Printers, select your printer, right-click, Printer Properties----General----Print Test Page 6) click Start----Device and Printers, select your printer, right-click, Set as default printer. 7) if those steps can not solve your problem, please contact to the printer providers to seek tech support. Link to comment Share on other sites More sharing options...
ChristianDJakes Posted August 19, 2014 Report Share Posted August 19, 2014 Tech support service provider has the right solution for your problem, Where you can get instant and proper solution. Here I suggest you some good technical support company name, which provider efficient PC and printer support. i.e. PC care support, Click4Support, Microsoft tech support… Link to comment Share on other sites More sharing options...
