WDCF Posted July 15, 2016 Report Share Posted July 15, 2016 whenever i clean out system patch it creates a point..and sometimes the patch file is around 1GB..thats something i dont want to fill up memory..even though i do have 438GB out of 500GB. MichaelCyday, orieptate, Richardpaile and 18 others 21 Link to comment Share on other sites More sharing options...
xilolee Posted July 15, 2016 Report Share Posted July 15, 2016 If you don't want windows creates restore points, you should disable system restore in Control Panel\System and Security\System, advanced system settings, system protection tab: select the system drive, click configure, tick disable system restore, click ok, click ok. If this is instead a feature request, if I correctly understood, you want a new setting (in wise disk cleaner settings): don't create restore points (disabled by default). JeffreyChups 1 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted July 18, 2016 Report Share Posted July 18, 2016 Wise Disk Cleaner only create system restore point when you run System Slimming. JeffreyChups 1 Link to comment Share on other sites More sharing options...
WDCF Posted October 1, 2016 Author Report Share Posted October 1, 2016 whoa. pardons for very belated reply. thx for replies. the problem I think is solved. JeffreyChups 1 Link to comment Share on other sites More sharing options...
xilolee Posted October 1, 2016 Report Share Posted October 1, 2016 And how did you solve it? JeffreyChups 1 Link to comment Share on other sites More sharing options...
WDCF Posted February 12, 2017 Author Report Share Posted February 12, 2017 sorry for late reply..i lied. i didnt solve it. it is what it is, cant change it. its fine, im used to it now. cheers. Link to comment Share on other sites More sharing options...
