Cer0n1m0 Posted May 5, 2015 Report Share Posted May 5, 2015 windows 8.1 kullanıcısım denetim masasında güvenlik duvarına tıkladıgım zaman pencerenın ustunde yanıt vermıyor dıyor acılmıyor translated from turkish the firewall does not open 8.1 The user control panel windows firewall After a click on the Window's response time is vermıy top DIYer acılmıyor Operating system:Windows 8.1 Single Language (64 bit) System root: C:Windows Available physical memory: 8101 MB CPU: Intel® Core i7-4712MQ CPU @ 2.30GHz Drive Info: C: 97,14 GB F: 833,86 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted May 5, 2015 Report Share Posted May 5, 2015 Hi. Didn't understand. Let's try with SFC: right-click start, click command prompt (admin), in the black window type sfc /scannow (press enter on your keyboard), wait till it finishes (about 20-50 minutes). If the final result of the SFC TOOL is equal to Windows Resource Protection found corrupt files but was unable to fix some of them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log, launch this command: copy %SYSTEMROOT%\logs\cbs\cbs.log %userprofile%\desktop\cbs.txt && findstr /c:"[SR]" %userprofile%\desktop\cbs.txt > %userprofile%\desktop\SR.txtAnd later attach here the SR.txt Otherwise post here the SFC result, if it is different from that sentence. Link to comment Share on other sites More sharing options...
