Georg
Wise JetSearch 2.01.85: 2nd search does not search
I'm using the quick search window to search for files and folders containing xyz in their names. Wise JetSearch finds results on different hard disks. I'm moving some folders so that every xyz should be on the same partition after that. When I'm reusing the results window to search again for xyz Wise JetSearch finds results still on different hard disks. This continues even after searching for abc and then again for xyz: Wise JetSearch finds results still on different hard disks where some of the files no longer exist.
Using the quick search window without closing the results windows returns the same wrong results.
Only after closing the results windows and searching again using the quick search window I get correct results: All xyz files and folders are on the same partition.
Thank you for your feedback.
But I didn't reproduce this problem. I test it as follow:
1, created xyz1.txt on D drive, created folder 2xyz on E drive, created monxyz3.txt on F drive.
2, opened Wise JetSearch, typed keywords xyz in quick search window (see screenshot before.jpg), didn't close result window.
3, moved xyz1.txt and monxyz3.txt to E drive
4, typed keywords xyz in quick search window
5, result was correct (see screenshot after.jpg)
Except: Path, file size and timestamp of both moved files are wrong (see screenshot after.jpg).
This happened also here:
Content of wjs.bat starts after this line:
md t:\xyzxyzt
md u:\xyzxyzu
copy wjs.bat t:\xyzxyzt\xyzxyz1.txt
copy wjs.bat t:\xyzxyzt\xyzxyz2.txt
copy wjs.bat t:\xyzxyzt\xyzxyz3.txt
copy wjs.bat t:\xyzxyzt\xyzxyz4.txt
copy wjs.bat t:\xyzxyzt\xyzxyz5.txt
copy wjs.bat t:\xyzxyzt\xyzxyz6.txt
copy wjs.bat t:\xyzxyzt\xyzxyz7.txt
copy wjs.bat t:\xyzxyzt\xyzxyz8.txt
copy wjs.bat t:\xyzxyzt\xyzxyz9.txt
copy wjs.bat u:\xyzxyzu\xyzxyz1.txt
copy wjs.bat u:\xyzxyzu\xyzxyz2.txt
copy wjs.bat u:\xyzxyzu\xyzxyz3.txt
copy wjs.bat u:\xyzxyzu\xyzxyz4.txt
copy wjs.bat u:\xyzxyzu\xyzxyz5.txt
copy wjs.bat u:\xyzxyzu\xyzxyz6.txt
copy wjs.bat u:\xyzxyzu\xyzxyz7.txt
copy wjs.bat u:\xyzxyzu\xyzxyz8.txt
copy wjs.bat u:\xyzxyzu\xyzxyz9.txt
Content of wjs.bat ends before this line.
Searching for xyzxyz -> nothing found
Starting wjs.bat
Searching for xyzxyz without closing results windows -> wjs1.jpg (wrong path, file size, timestamp)
Moving folder u:\xyzxyzu to t:\
Searching for xyzxyz without closing results windows -> wjs2.jpg (wrong file names)
Searching for xyzxyz after closing results windows -> wjs3.jpg (wrong timestamp 13:10 instead of 13:06; file names, path and file size are correct)
"Results on different hard disks" were not reproduced by this bat file and moving one folder. Perhaps I need more files for this error to occur.
Sorry for late.
Did the old version of wise jet search (v1.49) has this problem?
An "old" error is "wrong timestamp 13:10 instead of 13:06". The other errors in this thread I didn't see before.
