отображение языковой панели
пропала языковая панель из таск бара
translated from russian
display the Language bar
disappeared from the language bar TASK bar
Operating system:Windows 7 by Rushen v10.8 (32 bit) Service Pack 1
System root: C:Windows
Available physical memory: 2858 MB
CPU: AMD E1-2500 APU with Radeon HD Graphics
C: 174,19 GB
G: 88,29 GB
M: 203,18 GB
Internet Explorer: 9.0
Link to comment
Hi elnik! :)
The first thing that I asked myself is: what is Windows 7 by Rushen v10.8?
After googling a bit I found that it is an illegal version of windows...
Thus, I can't even try to help you because it is not allowed by forum rules (click).
Anyway if you would have not mentioned that you had that version, it would have been difficult to help you (because it is already difficult to help with original software, that it is well known... Figure yourself with software that it is not well known!)
For these problems, I must close the topic (nothing personal).
PS: someone tells that version could contain trojans, malware... I think you should use some operating system that is not compromised.
You can try linux or freebsd operating systems: they should be open source and free (most of the times).
Link to comment
Guest
This topic is now closed to further replies.
