AGI Posted March 12, 2015 Report Share Posted March 12, 2015 my windows helpfiles are not responding. or may not be present anymore. I suspect a baddy gets in here and intereres with setting. My firewall is ZoneAlarm. Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:Windows Available physical memory: 3893 MB CPU: Intel® Core i3 CPU M 370 @ 2.40GHz Drive Info: C: 222.83 GB D: 222.83 GB F: 931.51 GB Internet Explorer: 9.0 RichardGora 1 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted March 13, 2015 Report Share Posted March 13, 2015 No responding? Did you receive error message? Link to comment Share on other sites More sharing options...
xilolee Posted March 13, 2015 Report Share Posted March 13, 2015 Hi AGI. The "Windows help and support" not working is usually solved by the SFC tool, but could also be blocked by your firewall (especially if it blocks outcoming connections). Hence you could try to disable the firewall and launch the "help and support". Then, if that shouldn't work, you could try to launch sfc /scannow from an elevated command prompt, let it finish and check if it will solve the problem. How to run an elevated command prompt for Windows vista/seven users One of these three methods: - click start, all programs, accessories, right-click the command prompt in the list and click run as administrator, click yes on the user account control window that should appear - click start, type cmd in the searchbox, right-click the cmd in the list of results and click run as administrator, click yes on the user account control window that should appear - click start, type cmd in the searchbox, press and keep pressed ctrl + shift Keys on your keyboard, then press enter, click yes on the user account control window that should appear Link to comment Share on other sites More sharing options...
