seryoga Posted February 21, 2015 Report Share Posted February 21, 2015 ПРИ СОЗДАНИИ ОБРАЗА СИСТЕМЫ,А ТАКЖЕ АРХИВАЦИИ ЖЁСТКОГО ДИСКА С: ПРОИСХОДИТ ОШИБКА СОЗДАНИЕ ОБРАЗА СИСТЕМЫ И АРХИВАЦИЮ ПРОИВОЖУ НА ВНЕШНИЙ ЖЁСТКИЙ ДИСК С ДОСТАТОЧНЫМ СВОБОДНЫМ ПРОСТРАНСТВОМ 500 ГБ СКИНТЕ ПОЖАЛУЙСТА ФИКС ДЛЯ ИСПРАВЛЕНИЯ ЭТОЙ ОШИБКИ ИЛИ КАКУЮ НИБУДЬ УТИЛИТУ ТАКАЯ ПРОБЛЕМА У МЕНЯ УЖЕ СЛУЧАЛАСЬ И НЕ РАЗ ЗАБЫЛ ЧЕМ ИСПРАВЛЯЛ !!! translated from russian IMAGE SYSTEMS When creating an image system, and Archiving Hard disk c: there is an error creating the system image and archiving was producing an external hard disk with enough free space to 500 GB RESET PLEASE FIX to correct the error or some such problem any utility I had the case not once FORGOT than cure !!! screenshot проверка архива не удалось успешно завершить последнюю архивацию дополнительные сведения translated check archive did not successfully complete the last backup more information possible english error message (in Windows 7 control panel, backup and restore) Check your backup The last backup did not complete successfully More information Operating system:Windows 7 Ultimate (64 bit) Service Pack 1 System root: C:Windows Available physical memory: 8191 MB CPU: Intel® Core2 Quad CPU Q6600 @ 2.40GHz Drive Info: C: 465,76 GB J: 74,40 GB K: 372,61 GB N: 465,76 GB Internet Explorer: 11.0 Lapulyasr 1 Link to comment Share on other sites More sharing options...
xilolee Posted February 21, 2015 Report Share Posted February 21, 2015 What error code does appear when you click the "more information" button? Anyway, one of the possible causes could be the antivirus software. You could try to temporarily disable it and re-try to make your backup. If this doesn't solve the problem, uninstall it completely and re-try. The same applies to your firewall software, especially if it is not the Windows built-in firewall. If you don't like to uninstall your antivirus/firewall, you can perform a clean boot (removing the firewall/antivirus from the list, too), and re-try to make the backup. Link to comment Share on other sites More sharing options...
seryoga Posted February 21, 2015 Author Report Share Posted February 21, 2015 ПОМОГИТЕ МНЕ С ЭТОЙ НЕ ДОРАБОТКАЙ В ВИНДОВС 7 НЕ СНАСИТЬ ЖЕ ИЗАЭТОГО СИСТЕМУ !!! translated from russian HELP ME WITH THIS gaps in Vindovs 7 SNASIT NOT SAME IZAETOGO SYSTEM !!! screenshot проверка архива не удалось успешно завершить последнюю архивацию button: дополнительные сведения архивация (N:) локальный диск отключено размер архива: недоступно следующая архивация: последняя архивация: содержание: расписание: active window создание образа системы ошибка архивация. не удается найти указанный файл. (0x80070002) translated Check your backup The last backup did not complete successfully button: More information Archiving (N:) local drive disabled file size: Not Available The following archiving: last backup: table of contents: schedule: active window creating a system image Archiving error. I can not find the file specified. (0x80070002) Operating system:Windows 7 Ultimate (64 bit) Service Pack 1 System root: C:Windows Available physical memory: 8191 MB CPU: Intel® Core2 Quad CPU Q6600 @ 2.40GHz Drive Info: C: 465,76 GB J: 74,40 GB K: 372,61 GB Internet Explorer: 11.0 Link to comment Share on other sites More sharing options...
xilolee Posted February 21, 2015 Report Share Posted February 21, 2015 In your screenshot, it seems the drive N: isn't available... Maybe it's required to do your backup. Check also Error code 0x8100002F and or error code 0x80070002 when you back up files in Windows 7 Keep us updated. Link to comment Share on other sites More sharing options...
