Running WDC portable remotely via psexec doesn't work correctly
psexec remote portable
  • Please log in to reply
3 replies to this topic
#1 imurphy
imurphy
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 20 February 2015 - 10:44 AM
I've been playing around with trying to use WDC remotely on machines without pestering the user of the PC and I've noticed what I think is a bug in language handling, and maybe the handling of the config file.
If I run WDC from the screen on a machine it correctly opens in Spanish and displays the options I have selected. I am running the exe from a command prompt and have CD'd to the directory where WDC is stored. So far so good.
However if I use psexec to remotely connect to the same machine and cd to the directory and then type WiseDiskCleaner.exe -a it opens on the console of the machine, but in english. It also displays the notifications about having sucessfully run, which I think I have disabled.
It makes no difference if I connect as the logged in user or as the administrator account, it does exactly the same.
Has anyone tried using WDC via script or psexec, or remote execution of any kind?
This problem can be reproduced by doing the following from your own PC:
Download psexec from microsoft (www.sysinternals.com)
Open a cmd window
psexec -u <localhost>\<local admin> \\<pcname> cmd
once you have the remote command shell open
cd c:\wisediskcleaner\   (or where ever it is)
wisediskcleaner -a
this will launch the exe remotely but the systray icon displays on the console of the PC, as does the sucess message.
  • AppeptGause, RichardGora, Ekbergwef and 1 other like this
#2 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,188 posts
Posted 23 March 2015 - 10:08 AM
Thank you for your feedback.
We improved it. If the program doesn't find the config file, it will load system language settings.
Could you please try this edition again? (Download the attachment, copy WiseDiskCleaner.exe and replace the old one)
Attached File  WiseDiskCleaner.zip   1.5MB   1 downloads
Best Regards,
WiseCleaner.com
Follow us on:
#3 imurphy
imurphy
    Newbie
  • Members
  • Pip
  • 2 posts
Posted 26 March 2015 - 12:24 PM
I can confirm that this version behaves as expected. Thanks for the quick response.
I have noticed that the spanish translation contains some texts which make no sense. When the autoclean terminates it displays a small popup in the users systray which displays the text found in the [autoclean] section of the ini file
The current text makes no sense at all when displayed. Instead it should read something more like the following:
[AutoClean]
DiskSaved= de espacio liberado
Title=Terminado.
TraceCleanned= ficheros han sido limpiados.
also, the popup displays a number before each text, without any space. So the text displayed would be something like "10Gbspace freed up", rather than "10Gb space freed up". Hence I've inserted spaces, but I don't know if they get picked up.
Regards
-- Ian
#4 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,188 posts
Posted 27 March 2015 - 08:35 AM
Thank you.
We will update the translation asap.
I think a blank is not necessary. Because the number is green, different with the black text
Best Regards,
WiseCleaner.com
Follow us on:
Also tagged with one or more of these keywords: psexec, remote, portable
