WiseSystemMonitor feature requests, bug reports, updated translations
  • Please log in to reply
40 replies to this topic
#21 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,203 posts
Posted 14 July 2016 - 03:07 AM
Hey geogeo.gr,
When you uncheck the option "Starting with Windows", you can open Windows Scheduler Task to check whether the task named Wise System Monitor.job has been removed.
New product: Wise Anti Malware
Keep your PC in safe all the time!
Best Regards,
WiseCleaner.com
Follow us on:
#22 geogeo.gr
geogeo.gr
    Advanced Member
  • Members
  • PipPipPip
  • 52 posts
  • LocationGreece
Posted 14 July 2016 - 10:45 AM
In Windows Task Scheduler there was permanent. Deleted manually and now it works normally!
Thanks.
#23 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,203 posts
Posted 18 July 2016 - 08:59 AM
You'er welcome!
Best Regards,
WiseCleaner.com
Follow us on:
#24 duke
duke
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 25 July 2016 - 05:40 PM
Hello.
I have installed WiseSystemMonitor(WSM) v1.41.1.36. In floating window and main too, I didn't see download and upload speed and record;and Display Net Processes Only.
I can see it when I run WSM for first time,after that none.
I have a Net connection settings properly.
Thanks for your time and support.Kind regards.
Duke.
P.S.
 I attaches some screenshots.
Copyright © 2014-2016. by Duke. :ph34r:
#25 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,203 posts
Posted 26 July 2016 - 02:41 AM
Hey Duke,
Thanks for your feedback.
We will check and fix it shortly.
Best Regards,
WiseCleaner.com
Follow us on:
#26 xilolee
xilolee
    Advanced Member
  • Moderators
  • 4,336 posts
Posted 18 October 2016 - 03:41 AM
WSM correctly shows my memory manufacturer name (NANYA) BUT it doesn't show the Manufactor string (maybe is manufacturer more correct?) in hardware monitor, memory (between speed and serial number).
It probably wants the Manufacter string inside the Italian.ini (and also inside the other languages files).
Vice versa, the Manufactor string in hardware monitor, graphic card is present, BUT it doesn't show my graphic card manufacturer name (INTEL).
#27 xilolee
xilolee
    Advanced Member
  • Moderators
  • 4,336 posts
Posted 20 October 2016 - 10:34 PM
WISETdiFW64.sys memory dumps.7z
#28 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,203 posts
Posted 24 October 2016 - 07:44 AM
Thanks xilolee.
We will update the language file, and check the dump file.
Best Regards,
WiseCleaner.com
Follow us on:
#29 WC72
WC72
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 16 September 2017 - 05:53 AM
[BUG]
System Monitor constantly accesses the disk.  What is it doing?  How can I stop the disk activity ?
[FEATURE REQUEST]
needs a graph in the task bar, like Networx...
#30 jraju
jraju
    Advanced Member
  • Members
  • PipPipPip
  • 31 posts
Posted 18 September 2017 - 08:34 AM
Hi, Please check the fan and cpu RPM details in the program. The chasis and cpu fan speeds are shown as 10000 rpm and 17000 rpm, where as in other apps shows nearly in 2thousand rpm ranges
#31 jraju
jraju
    Advanced Member
  • Members
  • PipPipPip
  • 31 posts
Posted 20 September 2017 - 03:38 AM
The admin or moderator of this forum is taking much time in replying to the queries of the users. Did he look upon fan speed. If those bugs are cleared, this monitor would be the best to the users.
#32 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,203 posts
Posted 20 September 2017 - 05:59 AM
Thanks, but as I know, wise system monitor doesn't detect fan speed.
Best Regards,
WiseCleaner.com
Follow us on:
#33 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,203 posts
Posted 20 September 2017 - 06:01 AM
[BUG]
[FEATURE REQUEST]
How do you know system monitor constantly accesses the disk? Can you give me a screenshot of it?
Best Regards,
WiseCleaner.com
Follow us on:
#34 jraju
jraju
    Advanced Member
  • Members
  • PipPipPip
  • 31 posts
Posted 20 September 2017 - 11:40 AM
Hi, Please find enclosed the screenshot
#35 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,203 posts
Posted 21 September 2017 - 06:55 AM
I see, thanks for your feedback. we will check and fix it soon.
But, in my computer, the Fan speed is correct.
Which version do you use?
Attached File  cpu fan.png   38.48K   3 downloads
Best Regards,
WiseCleaner.com
Follow us on:
#36 jraju
jraju
    Advanced Member
  • Members
  • PipPipPip
  • 31 posts
Posted 22 September 2017 - 04:21 AM
Hi, The latest version 1.44 from your website
#37 jraju
jraju
    Advanced Member
  • Members
  • PipPipPip
  • 31 posts
Posted 13 November 2017 - 07:37 AM
Hi, admin did you check the fan speed raised by me
#38 WC72
WC72
    Newbie
  • Members
  • Pip
  • 4 posts
Posted 27 December 2017 - 08:33 AM
No, your forum is broken, cannot upload pictures or video:
  • You are not allowed to use that image extension on this community. [png]
  • Error You aren't permitted to upload this kind of file [mp4]
#39 xilolee
xilolee
    Advanced Member
  • Moderators
  • 4,336 posts
Posted 27 December 2017 - 06:58 PM
You can zip them up and use a website to upload images (dropbox, Google drive, ms OneDrive, et cetera)
#40 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,203 posts
Posted 02 January 2018 - 09:58 AM
Hi, you can send files to support@wisecleaner.com
Thanks.
Best Regards,
WiseCleaner.com
Follow us on:
