Methavas
WiseSystemMonitor feature requests, bug reports, updated translations
Hi all,
I downloaded this software and I tried to make it portable (i.e. use it without installation).
I achieved my goal, but I'm unable to see upload/download speed and components' temperature: the graphs are empty. Other functionalities (RAM usage and CPU usage) are shown without problems.
Is possible to create a portable version of this program or I'm forced to install it?
Thanks for help, regards
Methavas
PS: I'm using WSM v1.29 (latest version)
Hi,
you can make your portable version of lots of programs by using an extractor (you can use Universal Extractor).
Drag&drop your installer inside the extractor and it will create a portable version of program.
NB: not all program can be made portable; for some of them you cannot do anything and you have to install them.
Hope this will help you, I wait suggestion about my "problem" (can you make a portable version of WSM where you can see upload/download speed?).
Regards,
Methavas
I found some bugs. Take a look to Screenshots.
I'm just going to translate the program into the German language. Some things I'm not sure what they are intended to mean.
For what stand CSD?
What u mean with "Registered Org" ? Org for Organisation?
Graphic Card Activity Percent  0. - Means Graphic Card activity in Percent (%) ?
Engine Clock is GPU Clock?
PS: This list is not Up to date: http://www.wisecleaner.com/language.html
@djdanby,
Thank you for your feedback.
Is it the latest version v1.29?
Engine Clock is GPU Clock -------Yes
Graphic Card Activity Percent  0. - Means Graphic Card activity in Percent (%)----Yes
Registered Org, Org for Organisation -------------Yes (when you install Windows, the installation ask you to enter your organisation name)
CSD, the full name is Corrective Service Diskette http://en.wikipedia.org/wiki/Corrective_Service_Diskette)
BSOD (click on slow download)
BugCheck C2, {7, 126c, 4060002, ffffe000e65c4100}
*** WARNING: Unable to verify timestamp for WiseTdiFw64.sys
*** ERROR: Module load completed but symbols could not be loaded for WiseTdiFw64.sys
fffff8019b38c520: Unable to get MiVisibleState
Probably caused by : WiseTdiFw64.sys ( WiseTdiFw64+253a )
BAD_POOL_CALLER (c2)
The current thread is making a bad pool request. Typically this is at a bad IRQL level or double freeing the same allocation, etc.
Arguments:
Arg1: 0000000000000007, Attempt to free pool which was already freed
Arg2: 000000000000126c, (reserved)
Arg3: 0000000004060002, Memory contents of the pool block
Arg4: ffffe000e65c4100, Address of the block of pool being deallocated
I was modifying usercustom.ini, emule was running.
Using:
wise system monitor 1.3.9.35 (it wasn't running)
wise care 4.1.9 (it was running)
windows 10 home x64
DEP always on
custom scaling 150%
windows firewall
ashampoo antivirus 2016 (1.3.0)
gridinsoft antimalware (3.0.40)
Another one:
BugCheck C2, {7, 126c, 4060012, ffffe0012b1bee40}
fffff8000df84520: Unable to get MiVisibleState
Arguments:
Arg3: 0000000004060012, Memory contents of the pool block
Arg4: ffffe0012b1bee40, Address of the block of pool being deallocated
SYSTEM_SKU:
SYSTEM_VERSION:
BIOS_DATE: 08/10/2012
BASEBOARD_PRODUCT: imedia S2870
BASEBOARD_VERSION: V1.0
DUMP_FILE_ATTRIBUTES: 0x8 Kernel Generated Triage Dump
BUGCHECK_P1: 7
BUGCHECK_P2: 126c
BUGCHECK_P3: 4060012
BUGCHECK_P4: ffffe0012b1bee40
POOL_ADDRESS: fffff8000df84520: Unable to get MiVisibleState ffffe0012b1bee40
BUGCHECK_STR: 0xc2_7
CPU_COUNT: 2
CPU_MHZ: b54
CPU_VENDOR: GenuineIntel
CPU_FAMILY: 6
CPU_MODEL: 2a
CPU_STEPPING: 7
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN8_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 2
ANALYSIS_VERSION: 10.0.10240.9 amd64fre
LAST_CONTROL_TRANSFER: from fffff8000de37cf7 to fffff8000dd487a0
STACK_TEXT:
ffffd000`42476498 fffff800`0de37cf7 : 00000000`000000c2 00000000`00000007 00000000`0000126c 00000000`04060012 : nt!KeBugCheckEx
ffffd000`424764a0 fffff800`c20c253a : 00000000`00001002 00000000`00000000 00000000`0001a5c8 00000000`00000001 : nt!ExDeferredFreePool+0x547
ffffd000`42476580 00000000`00001002 : 00000000`00000000 00000000`0001a5c8 00000000`00000001 ffffe001`2b9ce5d0 : WiseTdiFw64+0x253a
ffffd000`42476588 00000000`00000000 : 00000000`0001a5c8 00000000`00000001 ffffe001`2b9ce5d0 fffff800`c20c2c0f : 0x1002
FOLLOWUP_IP:
WiseTdiFw64+253a
fffff800`c20c253a ?? ???
SYMBOL_STACK_INDEX: 2
SYMBOL_NAME: WiseTdiFw64+253a
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: WiseTdiFw64
IMAGE_NAME: WiseTdiFw64.sys
DEBUG_FLR_IMAGE_TIMESTAMP: 572c30db
BUCKET_ID_FUNC_OFFSET: 253a
FAILURE_BUCKET_ID: 0xc2_7_WiseTdiFw64!Unknown_Function
PRIMARY_PROBLEM_CLASS: 0xc2_7_WiseTdiFw64!Unknown_Function
ANALYSIS_SOURCE: KM
FAILURE_ID_HASH_STRING: km:0xc2_7_wisetdifw64!unknown_function
FAILURE_ID_HASH: {9953a442-ff5b-1921-0676-d8424e60bca1}
I searched a bit and this seems to be an error present only on windows 10.
Well, I found It's not only on win10. My win7 x64 got same problem here.
I also found that It will cause BSOD even if it's not running. I guess it's because the TDI driver is already loaded.
My Dump Analyze is as follow:
BugCheck 3B, {c0000005, fffff88005679621, fffff8800cfaeb30, 0}
*** WARNING: Unable to verify timestamp for WiseTDIFw64.sys
*** ERROR: Module load completed but symbols could not be loaded for WiseTDIFw64.sys
Probably caused by : WiseTDIFw64.sys ( WiseTDIFw64+3621 )
Wise System Monitor may incompatible with some hardware.
Can you give us your hardware info?
ACER Aspire 4745G
CPU: intel core-i5 520m
VGA: Intel HD Graphices + ATI mobility 5650
RAM: 4Gx2 Hynix HMT351S6CFR8C-PB
HDD: EZLINK T-34 256G SSD
Hello.
I have installed WiseSystemMonitor(WSM) v1.41.1.36. In floating window and main too, I didn't see download and upload speed and record;and Display Net Processes Only.
I can see it when I run WSM for first time,after that none.
I have a Net connection settings properly.
Thanks for your time and support.Kind regards.
Duke.
P.S.
 I attaches some screenshots.
