StefZZZ Posted June 21, 2013 Report Share Posted June 21, 2013 I think that some things can be added again WFH At WFH you can add check boxes > so if you want to unhide more file at same time it can be great. Wise Care 365 At Wise Care 365 the interface is greater ... but i thinks that with percentages (%) it would be better because time is not always right (time can be left). At right click can be add something to erase files/folders > this can be add also at Recycle Bin or you can put a box to drag & drop like first picture with WFH. RichardGora, MichaelRob, RonaldVovA and 2 others 5 Link to comment Share on other sites More sharing options...
Config Posted June 24, 2013 Report Share Posted June 24, 2013 I think that some things can be added again WFH At WFH you can add check boxes > so if you want to unhide more file at same time it can be great. Wise Care 365 At Wise Care 365 the interface is greater ... but i thinks that with percentages (%) it would be better because time is not always right (time can be left). At right click can be add something to erase files/folders > this can be add also at Recycle Bin or you can put a box to drag & drop like first picture with WFH. Hi Stef, Thanks for your suggestions. We will further improve the products according to your ideas. Link to comment Share on other sites More sharing options...
StefZZZ Posted July 12, 2013 Author Report Share Posted July 12, 2013 Link to comment Share on other sites More sharing options...
StefZZZ Posted March 11, 2015 Author Report Share Posted March 11, 2015 Now that is PRO version maybe reconsider check boxes to WFH to unhide more files/folders at same time it could be great. Link to comment Share on other sites More sharing options...
