Tahametin1999 0 Report post Posted January 7, 2015 Sürekli bu karşıma çıkıyo lütfen yadım edin translated from turkish {26EE0668 ... error Continuing these tactics against me, please help screenshot ::{26ee0668-a00a-44d7-9371-beb064c98683} Bu dosya bu eylemi gerçekleştirmek için ilişkilendirilmiş bir programa sahip değil. Lütfen bir program yükleyin veya zaten yüklü bir program varsa varsayılan programlar denetim masasında bu programla ilişkilendirin. translated ::{26ee0668-a00a-44d7-9371-beb064c98683} This file is not associated with a program to perform this action. Please install a program or associate these programs already in default programs control panel if you have installed a program. Operating system:Windows 7 Home Premium (32 bit) Service Pack 1 System root: C:Windows Available physical memory: 2045 MB CPU: Intel® Core2 CPU 4400 @ 2.00GHz Drive Info: C: 80,69 GB D: 68,26 GB Internet Explorer: 11.0 Share this post Link to post Share on other sites
xilolee 511 Report post Posted January 8, 2015 Download and run System Update Readiness Tool for Windows 7 (KB947821) [October 2014] From an elevated command prompt, launch (Windows installation cd could be necessary): sfc /scannowWait till it finishes (15-50 minutes).If the final result is equal to Windows Resource Protection did not find any integrity violations or equal to Windows Resource Protection found corrupt files and successfully repaired them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log, launch this command: copy %SYSTEMROOT%\Logs\CBS\CheckSUR.log %userprofile%\desktop\CheckSUR.txtAfter it, you should find checkSUR.txt on your desktop: post it here. Instead if the final result of the SFC TOOL is equal to Windows Resource Protection found corrupt files but was unable to fix some of them. Details are included in the CBS.Log %WinDir%\Logs\CBS\CBS.log, launch both the previous command in the code above AND also this command: copy %SYSTEMROOT%\logs\cbs\cbs.log %userprofile%\desktop\cbs.txt && findstr /c:"[SR]" %userprofile%\desktop\cbs.txt > %userprofile%\desktop\SR.txtAfter those two commands, you should find three files on your desktop: checkSUR.txt, cbs.txt and SR.txt: post here the checkSUR.txt and the sr.txt.If the last command won't work, try these (one by one): copy %SYSTEMROOT%\logs\cbs\cbs.log %userprofile%\desktop\cbs.txt findstr /c:"[SR]" %userprofile%\desktop\cbs.txt > %userprofile%\desktop\SR.txt How to run an elevated command prompt for Windows vista/seven users One of these three methods: - click start, all programs, accessories, right-click the command prompt in the list and click run as administrator, click yes on the user account control window that should appear - click start, type cmd in the searchbox, right-click the cmd in the list of results and click run as administrator, click yes on the user account control window that should appear - click start, type cmd in the searchbox, press and keep pressed ctrl + shift Keys on your keyboard, then press enter, click yes on the user account control window that should appear Share this post Link to post Share on other sites
