MyWin7-Home Posted December 20, 2014 Report Share Posted December 20, 2014 電腦自動重新啟動(約使用15分鐘後} 若2天未開機.在開機時會無法正常啟動.而會啟動自動修復 translated from chinese Computer automatically restarts Computer automatically restarts (approximately 15 minutes after use} If the two days is not turned on at boot time will not start properly. And will start automatically fix Operating system:Windows 7 Home Premium (32 bit) System root: C:Windows Available physical memory: 3061 MB CPU: Intel® Pentium® D CPU 2.80GHz Drive Info: C: 35.37 GB D: 39.06 GB F: 298.09 GB Internet Explorer: 9.0 Link to comment Share on other sites More sharing options...
xilolee Posted December 22, 2014 Report Share Posted December 22, 2014 Remove carefully and gently the dust from the inside of your machine. Link to comment Share on other sites More sharing options...
