leonard5185 Posted June 20, 2013 Report Share Posted June 20, 2013 In Disk Cleaner, there is a section to clean "files" and another for "traces". Am familiar with the named files on disk that can be a folder, file, text, executable, DLL, etc., but can you describe just what the "traces" are? I never heard of them... I looked in the online help, but no explanation there... Thank you. Gresgflign, nohnigefearxv76 and Bosaldbof 3 Link to comment Share on other sites More sharing options...
Config Posted June 20, 2013 Report Share Posted June 20, 2013 In Disk Cleaner, there is a section to clean "files" and another for "traces". Am familiar with the named files on disk that can be a folder, file, text, executable, DLL, etc., but can you describe just what the "traces" are? I never heard of them... I looked in the online help, but no explanation there... Thank you. Hi Sir, Please refer to the attached pic. "Traces" is another word for "records". Clean the traces can help your PC keep slimmer and further protect your privacy. april 1 Link to comment Share on other sites More sharing options...
