dong Posted November 7, 2014 Report Share Posted November 7, 2014 시작페이지가 고정이되어 인터넷 옵션/일반/ 홈페이지를 바꿔도 변경이 안됩니다 translated from korean Start Page Fixed The start page is fixed This should not change when you change Internet Options / General / Home Operating system:Microsoft Windows XP (32 bit) Service Pack 3 System root: C:WINDOWS Available physical memory: 3567 MB CPU: Intel® Xeon® CPU W3505 @ 2.53GHz Drive Info: C: 39.99 GB D: 425.76 GB F: 465.65 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted November 7, 2014 Report Share Posted November 7, 2014 Right click on the IE desktop icon (and Quick Lunch bar icon), click Proprieties, click Shortcut tab, find Target The default value should be "C:\Program Files\Internet Explorer\iexplore.exe" If not, please correct it. Link to comment Share on other sites More sharing options...
xilolee Posted November 8, 2014 Report Share Posted November 8, 2014 Use the softwares listed in Free tools (Anti-malware, anti-spyware, anti-virus) that you could use to inspect your computer. Adwcleaner should suffice to remove the problem, but other scans with the other softwares won't hurt. Link to comment Share on other sites More sharing options...
