справка
при нажатии f1 на рабочем столе не появляется окно справка.
translated from russian
reference
when you press f1 on the desktop is not a window reference.
screenshot
справка и поддержка
ошибка при запуске справки и поддержки.
возникла неполадка центра справки и поддержки windows. для просмотра справки в интернете см. вебсайт windows.
translated
Help and Support
error starting Help and Support.
a problem with the Help and Support windows. To view help on the internet see. website windows.
possible english message
Windows help and support
Windows help and support can't start
There is a problem with Windows help and support.
To view our online help content, visit the Windows website.
System root: C:Windows
Available physical memory: 1786 MB
CPU: AMD Athlon II P320 Dual-Core Processor
C: 95,65 GB
D: 200,43 GB
F: 1,99 GB
Internet Explorer: 11.0
Link to comment
Open an elevated command prompt (started as an administrator) and try the SFC tool:
sfc /scannow (press enter key on your keyboard)
This usually solves the problem.
How to run an elevated command prompt for Windows vista/seven users
One of these three methods:
- click start, all programs, accessories, right-click the command prompt in the list and click run as administrator, click yes on the user account control window that should appear
- click start, type cmd in the searchbox, right-click the cmd in the list of results and click run as administrator, click yes on the user account control window that should appear
- click start, type cmd in the searchbox, press and keep pressed ctrl + shift Keys on your keyboard, then press enter, click yes on the user account control window that should appear
Link to comment
