jschwind Posted October 4, 2014 Report Share Posted October 4, 2014 Wlan funktioniert an meinem PC nicht. aber an den anderen Geräten wie Laptop und Smartphone gibt es keine Probleme. translated from germanWifi does not workWifi does not work on my PC. but on the other devices such as laptops and smartphones, there are no problems. Operating system:Windows 7 Home Premium (64 bit) Service Pack 1System root: C:WindowsAvailable physical memory: 1791 MBCPU: AMD Athlon II X2 215 ProcessorDrive Info:C: 284,99 GBInternet Explorer: 11.0 Link to comment Share on other sites More sharing options...
donut Posted October 14, 2014 Report Share Posted October 14, 2014 Hi there, We'd like to help you with the issue. Please try to do as the following instructions to check out if it can help you out. Go to "Network and Sharing Center"----Change adapter settings (in the left side)----right click "Local Area Connection" and click "Enable" Thanks! Link to comment Share on other sites More sharing options...
