[Solved - WinXP-SP3] Warning: Unresponsive Plugin; Shockwave flash may be busy, or it may have stopped responding.
LOCKS THE PAGES freezes up the copmuter. Have to hit Esc/Alt to try to move script.Then a screen appears saying >>script to busy pluging click to continue or click stop plugging.Having to use Task manganer to move links through the plugging
Windows XP professiornal - version 2002
Sevrvice pack 3
2.93 ghz
504 of ram
not sure if its 32 or 64
System root: C:\WINDOWS
Available physical memory: 502 MB
CPU: Intel® Celeron® CPU 2.93GHz
C: 37.27 GB
E: 232.83 GB
Internet Explorer: 8.0
Link to comment
Try follow steps to to fix unresponsive script error in Firefox:
1. Open new tab in Firefox and type “about:config” without quotes | Enter.
2. In the filter filed type “dom.max_script_run_time” without quotation | Press Enter
3. Now double click on Enter and Type “20” in pop up box | Press Enter.
4. Close newly opened tab.
5. Restart Firefox.
Link to comment
I went to about:config which I had bookmarked from research and noticed that the phrase u mentioned was at 40.
what is strange is that I had changed that from 0 to 20 last week.However,when I went back to look because of your post it had moved back to 40 WTF ? I know this because I'm copying/pasting in text Doc.every change I make in about:config.
I have reset the # back to 20 !
Thank u for your reply :)
Link to comment
