NORTON Software\wow6532 registry errors
norton
  • Please log in to reply
4 replies to this topic
#1 handyboss
handyboss
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 27 September 2014 - 08:57 PM
Why does WRC keep flaggin Norton?   Always get about 12 "Software\wow6532...." registry errors on Norton.
Won't allow the fix to work.
I've deleted and reinstalled Norton (from Comcast), running Win7.
  • AppeptGause, HerculEn, RudyJainy and 6 others like this
#2 xilolee
xilolee
    Advanced Member
  • Moderators
  • 4,333 posts
Posted 30 September 2014 - 07:11 AM
Hi handyboss.
It could be useful for developers if you posted the registry Keys that you think they shouldn't be marked/deleted.
#3 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,188 posts
Posted 15 October 2014 - 09:13 AM
@handyboss,
Firstly you must to know Norton is security software, it has system permission. But wise registry cleaner is a utility software, it only has user permission. In Windows system, system permission is higher than  user permission. So, wise registry cleaner cannot remove registry items that created by Norton.
But thank you for your feedback, I will send it to developer team.
Best Regards,
WiseCleaner.com
Follow us on:
#4 dmitriy1980
dmitriy1980
    Newbie
  • Members
  • Pip
  • 1 posts
Posted 17 November 2014 - 05:45 PM
@handyboss,
If this is the case I would recommend excluding "system permisisons" at the code level, if we can't interact with values that your software produces. If this is not acceptable, then other option might be a setting in the software where it's up to a user to either see those results or not, with default option NOT to show it.
#5 wisecleaner_admin
wisecleaner_admin
    Administrator
  • Administrators
  • 2,188 posts
Posted 18 November 2014 - 07:25 AM
@dmitriy1980
Thank you for your suggestion.
We will consider it.
Best Regards,
WiseCleaner.com
Follow us on:
