brim Posted September 11, 2014 Report Share Posted September 11, 2014 Fine application. I've used WFH portable for about a week, but it's now experiencing problems soon after I open it. It may not be compatible with my system and system applications - it "freezes" after opening a file, or a video, or starting an application - can't be sure yet. It's not on the system, so I can't use Add/Remove. I would like to research this problem, but in the meantime I wish to safely remove WFH, with all files left safely accessible on the Flash Drive. Does anyone know how to do this with access to all files currently protected by it, assured? Appreciate the assistance. Cheers. IrvingFies, TimothySl, AppeptGause and 1 other 4 Link to comment Share on other sites More sharing options...
xilolee Posted September 11, 2014 Report Share Posted September 11, 2014 You can't use add/remove programs just because it is portable, it doesn't need to be installed. Link to comment Share on other sites More sharing options...
brim Posted September 12, 2014 Author Report Share Posted September 12, 2014 Thanks Xilo. I understand, but if I simply delete/remove the portable edition will I lose any files? I'm concerned because the hidden or open status of files changes without my input, sometimes after reboot, sometimes just closing and reopening the app. In other words, do I need to open all files, copy them to a folder on the flash drive and then remove/delete the app? Link to comment Share on other sites More sharing options...
xilolee Posted September 12, 2014 Report Share Posted September 12, 2014 Are you writing of files you have hidden? What OS are you using? It should support Windows XP, server 2003, Vista, server 2008, Win7/8 (both 32-bit and 64-bit). It seems it works on win 8.1 too, even if it is not written in the WFH help on the website. Link to comment Share on other sites More sharing options...
brim Posted September 12, 2014 Author Report Share Posted September 12, 2014 Thanks again Xilo. Can't imagine anyone else experiencing this issue. It still freezes/crashes, but it's something about my personal security config. Probably staring me in the face, but system is standard yet different. Let me ask this. Can you place the files in WFH in order by "Type", or some other order? Link to comment Share on other sites More sharing options...
xilolee Posted September 13, 2014 Report Share Posted September 13, 2014 It seems only by name. Link to comment Share on other sites More sharing options...
brim Posted September 15, 2014 Author Report Share Posted September 15, 2014 Thanks. It is possible that having ordering option could be an added feature in the future? Link to comment Share on other sites More sharing options...
xilolee Posted September 15, 2014 Report Share Posted September 15, 2014 You can make feature requests in the apposite thread. Link to comment Share on other sites More sharing options...
