mesley Posted September 6, 2014 Report Share Posted September 6, 2014 (edited) 一樣無法解決您的系統管理員已停用登錄編輯 translated from chinese The same can not solve your system administrator has disabled the Registry Editor possible (because i can't read chinese) sentences inside the screenshot, in english: registry editor registry editing has been disabled by your administrator Operating system:Windows 7 Professional (64 bit) System root: C:\Windows Available physical memory: 8103 MB CPU: Intel® Core i3-4150 CPU @ 3.50GHz Drive Info: C: 112.60 GB D: 405.57 GB E: 413.34 GB Internet Explorer: 8.0 Edited September 7, 2014 by xilolee added translation Link to comment Share on other sites More sharing options...
xilolee Posted September 7, 2014 Report Share Posted September 7, 2014 1) Have you already used the solution proposed by wise pc 1st aid about that problem? 2) Have you already tried to use gpedit.msc? - Windows key + R key opens the run window, type gpedit.msc, press enter - go to User Configuration --> Administrative Templates --> System, in the right pane select Prevent access to registry editing Tools and set it to Not configured or Disabled. 3) Have you already tried the other tools listed in techdows.com - 7 Ways to Fix "Registry editing has been disabled by Your administrator" (click) ? Link to comment Share on other sites More sharing options...
