CBarry Posted September 2, 2014 Report Share Posted September 2, 2014 Randomly, I will lose sound. When I check the speaker icon it appears everything is fine. The driver says it's the most current. When I reboot, the problem disappears for a day or so. When I check the event log, I see Schannel Source, Event ID 36887, code 40. I cannot find anything helpful about those codes. Any suggestions to resolve this recurrent problem? Thank you. Link to comment Share on other sites More sharing options...
wisecleaner_admin Posted September 4, 2014 Report Share Posted September 4, 2014 When did you update the sound card driver? Before the update, do you have same problem? If not, please roll back the sound driver to the earlier version Link to comment Share on other sites More sharing options...
xilolee Posted September 4, 2014 Report Share Posted September 4, 2014 Try to use the Free tools (Anti-malware, anti-spyware, anti-virus) that you could use to inspect your computer. Link to comment Share on other sites More sharing options...
