WJSwanson Posted July 18, 2014 Report Share Posted July 18, 2014 The following error comes up when I try to launch links and some other items, which was noticed after internet explorer would not longer open. I have installed Mozilla Firefox to access the internet while I attempt to correct this issue. The error mentioned above is: The ordinal 701 could not be located in the dynamic link library iertutil.dll Operating system:Windows 7 Home Premium (64 bit) Service Pack 1 System root: C:\Windows Available physical memory: 8151 MB CPU: Intel® Core i7 CPU 860 @ 2.80GHz Drive Info: C: 920.59 GB D: 0.04 GB Internet Explorer: 8.0 Link to comment Share on other sites More sharing options...
xilolee Posted July 22, 2014 Report Share Posted July 22, 2014 1) Try the softwares listed in Free tools (Anti-malware, anti-spyware, anti-virus) that you could use to inspect your computer. 2) Press Windows key on your keyboard (and keep it pressed), then press R key, release the two keys (Windows + R), it will open the run window, type SystemPropertiesAdvanced and press enter. Click the environment variables... button (on your screen)Find the path variable and check if c:\windows\system32 (or %SystemRoot%\system32) is present between all the paths If not, add it at the end of the entire string (preceded by a semi colon) and click Always ok. 3) Try to uninstall/reinstall MSIE 11 (from control panel, programs, turn Windows features on or off) 4) Open a command prompt and type (or copy/paste) this command: C:\WINDOWS\system32\regsvr32 C:\WINDOWS\system32\IERTUTIL.DLL (press enter key on your keyboard)5) Check if you have got IERTUTIL.DLL in c:\windows\system32If not, you can extract it from your Windows installation cd, or other places; check Chkdsk function not working Windows 7 Pro 32 Upgrade from Vista for more informations. Link to comment Share on other sites More sharing options...
