walkerpbus
Missing 2 Functions
1. Settings say the the startup booster should be called on bootup, yet it doesn't happen, says not setup right.
2. Don't know where the settings are for daily PC Checkup but it doesn't happen.
Both of these phenomena happen on 1 Windows 7 machine, (others work fine): I don't know how to set the settings or make it happen
Dos anyone have any suggestions? :-(((
Hi Walkerpbus,
Please refer to: menu --- settings--- general --- system:
Please have the first two items checked if you want them.
Have a try! :)
A screenshot pic attached is for your reference.
Hi Walkerpbus,
Have a try! :)
I'm sorry, but I already had them checked without any results at all on the offending system.
I've also inquired to the vendor via their support email; still with no result! :(
Hi, please check this screenshot and set the certain function to see if the problem fixed.
Menu---Settings---Scheduler
Sometimes our reply via email may be filtered to spambox,
so please check it and add our email to contact list to avoid the situation. :)
Hi Walkerpbus,
Have a try! :)
1. Checked the settings & they were same as what everyone recommended. 1. Didn't see the screenshot pic but the description explained it.
Set scheduler as you specified.
