Tips Today: How to access Control Panel and PC Settings in Windows 8
How to open the Control Panel in Windows 8
Step 1
Navigate to the Desktop part of Windows 8. You can do this by hitting the Windows key or clicking the Desktop tile.
Step 2
Open the Charms bar by swiping in from the right hand edge of the screen (for touch) or moving your mouse to the right hand corners of the screen.
Step 3
Click Settings.
Step 4
Click Control Panel.
Windows 8 control panel
Alternatively, you can search for the Control Panel by the Search section of the Charms bar. It's also found in the System section of the Apps list.
How to open PC Settings in Windows 8
Step 1
Open the Charms bar as per the instructions above.
Step 2
Click on Settings.
Step 3
Click on Change PC Settings.
Link to comment
